No problem, here's how I started shaping the scoop.I'd be eager to see what primitive you started with and the settings for Spherify that you used to create the bowl (scoop) of that spoon. Thanks.
Select the top edge and use the Cover polygon tool and then move
the new geometry out and scale it flat with the Transform Tool.
Then from the top view, scale to match the blueprint.
Then use Cover and move to follow the outer contour of the scoop.
