I guess you need a detailed step-by-step video as it seems you´re not really following the already given instructions. What do you think?
Camera-> Output->Resolution?Hey.. How do I make the Render bigger, Render Window....
.. how do I centre the object on the state.. Like show all...
Thank you
Destiny..
I´m pretty sure PNG is a lossless image file format in its current state and Cheetah3d renders animation data to image sequences all the time. Proof: hit ctrl+click on the rendered file->Show in Finder and there it is.Hi..
If I add a base colour like red or green, the render is really nice.. However, if I add shiny steel or gold the entire render is black... Why is that...??
Also.. is it posible to render as a 24bit PNG...???
That option has many uses.. Like render a 24bit png sequence, which provides for really high quality animations..
Destiny...
Click&drag from the bottom right corner? (seriously?)
Zoom out? Select all hit Focus Camera?
Specular and refractive features can´t be baked as you can check by yourself by looking into the Baking-tag properties->Channels.
I´m not sure why you´re constantly ignoring my advices:Hi Frank.. All web graphics are Lossless.. But that does not matter, I am not printing the graphic..
I did as you said, dragged the corner of the Render Manager Window out but the image dose not change size.. Even if I make the model as big as I can on the stage, the render is still the same size..
Destiny..
Since when? Try an JPEG and see the difference for instance.Hi Frank.. All web graphics are Lossless..
Check the following files: Help-> Cheetah3d samples -> Rendering -> Pig.jas/Illustrator tutorial.jas. In essence you need an environment to be reflected by your shiny objects otherwise it doesn´t make sense like in a real world situation - achieved by the HDRI-tag attached to the camera.Ignoring the baking of textures.. How do I render a shiny metal... So I get a rendered image...
Destiny..
