- Messages
- 6,547
Suggestions for C3D Book
Edit:
Here's the current Table of Contents
Why Learn 3d Graphics?
Why Cheetah 3d?
Prerequisites
Cheetah 3d’s Best Feature: The Community
Who is this book for?
Classroom Use
3d in a nutshell
From Blank Slate To Rendered Image in Fifteen Minutes
3d Text: Your Name in Lights
Package Mockup: Imperial Cereal
Simple Game Component: Biplane
Cheetah 3d’s Key Features
What’s New in v6?
Just Enough to be Dangerous
Navigating the 3d view
Modes
Mesh Editing Modes
Select vs. Transform
The Transform tool
Center Manipulator Modes
Two Axis Scaling
Working with Selections
The Object Browser
Primitives
The Properties Panel
Common Tags
Meshes
Editable Meshes
Selecting and Moving Stuff
Duck… I mean Extrude and Cover
Create Polygon
Bridge
Fill Hole
Scalpel
Ring Cut
Modifiers
Stacking Modifiers
Toggling Modifiers
Splines
Creators
Sweeps
Booleans
Toggling Creators
Animation
Keyframes
How Keyframes Work
Character Animation & Bones
Materials
Material vs. Texture
Basic Materials
Reflection
A Whole Bunch of Nothing: Reflection Maps
Hint: Make Shiny Objects Look Fabulous
Transparency and Refraction
Lighting
The Light Object
Image-Based Lighting
Aside: limitations of image-based lighting
The Sky Light Object
Rendering
Camera Objects
Other Cheetah 3d Resources
Quick Start Tutorial
Instructional Videos
Online Help
The Cheetah 3d Community
Modeling
Modeling Overview
Visual References
Level of Detail
The Simplest Method
Judging your own work
Give a Damn
Approaches to Modeling
Box Modeling, Subdivision Surfaces, Splines, and NURBS
A Tale of Two Wineglasses — oh, a B-29 bomber: The Advantages & Disadvantages of Splines
Tutorial: Making a Wineglass with a Spline and the Lathe Creator
Tutorial: Making a Wineglass with using Box Modeling and Subdivision
When making stuff with lathes causes problems…
Tutorial: Modeling a Wing Root
Solid Modeling
Hard Edged vs. Organic
What is a mesh?
Making a mesh editable
Polygon Objects (Primitives)
Ball, Box, Cone, Cylinder, Disk, Plane, Polyhedra, Relief, Stair, Torus, Tube
Splines
Why use splines?
Importing Splines
Creators
Polygon/Box Modeling
Polygon Tools
Bridge
Troubleshooting the Bridge Tool
Modeling by Eye
Creating a Modeling Sheet & Preparing It For Use
Modeling from "Blueprints"
Symmetry
Controlling Curves
Modeling Tricks & Techniques
Joining Meshes
Splitting Meshes
Working with Primitives
Modeling a Hole (without Booleans)
Creators, Modifiers, and Tags
Creators
Boolean
Chain
Extrude
Lathe
Sweep
Polyplane
Symmetry
Modifiers
Subdivision
Replicators
Array
Build
Ring
Deformations
Bend
Bulge
Displace
Skew
Spherify
Symmetry
Taper
Transform
Twist
Warp
Understanding How Creators, Tags, and Modifiers Interact
“Collapsing” Creators and Modifiers
Partially Collapsing Creators and Modifiers
Keeping the modifier chain around for later
Advanced Modeling
Character Modeling
Symmetry
Subdivision
Quads, UV-Mapping, Topology & Loops
Sculpting
Sculpting Workflows
Modeling Joints
Low poly vs. high poly
Tricks and Techniques
Putting a square hole in a round peg
Building Rounded Objects
Precision
Hard Edged Modeling
Solid Modeling*
Importance of Normals
How solidity is inferred
Physics & Modeling
Materials
Creating Materials
Flat Colors
The Material Shader
Image-Based Materials
Bump Maps
Quick and Dirty Bumpmaps
Reflective Materials
Reflection Map Example: Cracked Mirror
The Metal Shader
The Car Paint Shader
Transparent Materials
Refraction
Fresnel Effect
The Dielectric Shader
How Materials Work
Complex Materials
What does “multiplying a color” mean?
Aside: Color Arithmetic
Specular vs. Reflected Highlights
Texture Mapping
UV Coordinates
Coordinate Spaces
The Material Tag
All About Nodes
Node Types
Connecting Nodes
Visualizing an Output Channel
Channel Types
Converting Between Types
Nodes in Depth
Shader Nodes
Texture Nodes
Constant Nodes
Filter Nodes
The State Node
The Instance Node
Math Nodes
Creating Materials from Scratch
Some Procedural Textures
Using a texture as a selector
Terrain Shaders
Planet Shaders
Cross Product Measures Perpendicularity
Dot Product Measures Closeness of Direction
Faking Fresnel Effects
A Color is a Vector is a UV Coordinate
OMG! You didn’t tell me there’d be math!
Points
Planes
Planarity, Coplanar
Vector
Normal
Dot Product
Cross Product
Putting it all together
Diffuse Illumination
Reflection
Refraction
Fresnel Effects
The Material Assignment Tag
Procedural Materials
UV-Mapping
Texturing
Texture Painting
Particles
Getting the most out of Cheetah 3d’s Particle System
Workarounds
Faking Volumetrics
Faking Glowing Particles
Instances
Emitters
Effectors
Particles as Detail or Decoration
Lighting
How Lights Work
Lighting Basics
Shadows
Soft Shadows
Reflected Lights
Specular vs. “Real”
Advanced Lighting
Global Illumination
Lighting with Emissive Objects
Caustics
Under the Hood
Fine-Tuning Caustics
Camera Properties
Shadow Catchers
Animation
Animation Overview
The Animation Timeline Controller Doohickey
How Keyframes Work
Animation Concepts
Simple Animation
Path Animation
Basic Rigging
Forward Kinematics
Inverse Kinematics
Character Animation
Advanced Rigging*
Physics
Bullet Physics
Introduction to Physics
Physics & Modeling
Physics & Animation
Rendering
Rendering Overview
How Raytracing Works
Stochastic Sampling Tricks
Environments
I made a metal object and it’s black
I want my metal object to look like metal, but I don’t want a backdrop
Backdrops
I want a transparent background
I want to add a rendered element to a photograph
I want an outdoor background
I want to add a rendered element to a video
Reflections
Lighting
The HDRI Tag
The Radiosity Tag
Realism
The Golden Rule: cg images are made convincing by imperfection
Cartoon Looks
Simple Caricatured Models
Cartoony Materials
Lush Unrealism: Painterly Rendering
Renderer Settings
Baking
Render Manager
Where are all those rendered images stored?
The Render Tag
Mocking up a Scene
Nice Test Renders
Product Shots
Natural Environments
Interiors
Rendering a Panorama
Creating your own HDRIs for Image-Based Lighting
Rendering a Sky Box
Skybox Utility
Orthographic Rendering
Managing Complexity
Folders
Smart Objects
Takes
Mastering Cheetah 3d’s Interface
Custom Hotkeys
Custom View Layouts
Quantization
Snapping
Cheetah 3d Under the Hood
Preferences
Render Cache
Script Files
.jas Files
Workflow
Workflow Overview
Points of No Return
Collapsing Symmetry
Rigging & Animation
Morphing
Combining Meshes with Different Materials
UV Mapping Across Multiple Meshes
Baking
Importing Stuff
Exporting Stuff
Working with an external image editor
Working with other 3d modelers
Working with other renderers
High Dynamic Range Images
Post Production Workflow
Video Production Workflow
Unity Workflows
iBook Author Workflows
Archviz Workflows*
Scripts
Some Very Useful Scripts
Basic Interface Enhancements
Modeling
Animation
Texturing and UV-Mapping
Rendering
Particles
Using Scripts
Assigning Hotkeys to Scripts
Writing Scripts
Basics
The Console
Feeling Your Way Around
Some Useful Patterns
Appendices
Glossary
Copyright, Intellectual Property
Unbiased Rendering, Physically-Based Rendering
Does this matter to Cheetah 3d Users?
Axes, X Axis, Y Axis, Z Axis
Quaternion
Inverse Kinematics
Forward Kinematics
Scene Graph, Object Browser, Hierarchy
Parent, Parent Object
Child, Children, Child Object
Convex Polygon
Quad
Triangulation, Tessellation
Interpolation
F-Curve
Easing
Keyframe
Texture, Bitmap
Non-destructive Modifier Chain
Creator
Creator vs. Modifier
Node-Based Shader, Material
Spline
Sweep
Lathe
Extrusion
Frustrum
Space, Coordinates
Procedural Texture
Image Space
Texture Space, UV Space, UV Coordinates
Local Space, Local Coordinates
Global Space, Global Coordinates
Vector Motion Blur
Normal
Normal Map, Bump Map
Displacement Map
Specularity, Shininess, Specular Size, Hardness
Gouraud Shading
Phong Shading
Mesh Weight, Mesh Topology, Retopologize
Box Modeling
Solid Modeling
Tags
Bevel, Inner Extrude
NURBS
God-Rays, Volumetrics
Render-to-Layers
Faking Render to Layers
Glows
Achieving “Real” Glow Effects
Faking Glow
Maximum Image Size
SSS, Sub-surface Scattering
Instrumenting Rigs
Morphing
Network Rendering
CUDA, OpenCL, GPU-Accelerated Rendering
Unbiased Renderer, Physically Based Renderer
Plugins
Image Formats
File Size
Bit Depth
Lossy or Lossless
Production or Delivery
Alpha Channel Support
Alpha Channels
Use Alpha?
Which Way Around?
Premultiplied
3d File Formats
Geometry
Animation
Lighting, Cameras, Material Definitions, Rigs
Video Compression
File Size
Lossy vs. Lossless
Picking Your Target(s): Web, iPhone, iPad, etc.
Faking Motion Blur
Other Resources
Websites
Books
I left out page numbers because this post was going to exceed the 10k char limit for the forum. No, I do not guarantee all the chapters will be written before Martin launches Cheetah 3d v6, but they will be written — some may be merged and there will be reorganization. The text is a little over 50% complete as of now (and the book is ~180 pages so far).
I'd love any suggestions you might have for things to put in the C3D Book I am writing. Basically ideas along the lines of:
a) UI Shortcuts and Things I wish I'd known (classic example: double-clicking primitives to make them into editable meshes)
b) Gotchas (classic example: rendering metal requires HDRI map)
c) Tutorials I would love to have
Either reply to this thread or email me at tonio AT loewald DOT com.
Cheers!
Edit:
Why Cheetah 3d?
Prerequisites
Classroom Use
3d in a nutshell
What’s New in v6?
Modes
Mesh Editing Modes
The Transform tool
Two Axis Scaling
The Object Browser
Primitives
Common Tags
Meshes
Editable Meshes
Create Polygon
Bridge
Fill Hole
Scalpel
Ring Cut
Modifiers
Stacking Modifiers
Toggling Modifiers
Splines
Creators
Sweeps
Booleans
Toggling Creators
Animation
Keyframes
How Keyframes Work
Materials
Basic Materials
Reflection
Lighting
The Light Object
Rendering
Camera Objects
Online Help
Modeling
Modeling Overview
Visual References
Level of Detail
The Simplest Method
Give a Damn
Solid Modeling
What is a mesh?
Splines
Why use splines?
Importing Splines
Creators
Polygon Tools
Bridge
Modeling by Eye
Symmetry
Controlling Curves
Joining Meshes
Splitting Meshes
Creators
Boolean
Chain
Extrude
Lathe
Sweep
Polyplane
Symmetry
Modifiers
Subdivision
Replicators
Array
Build
Ring
Deformations
Bend
Bulge
Displace
Skew
Spherify
Symmetry
Taper
Transform
Twist
Warp
Advanced Modeling
Character Modeling
Symmetry
Subdivision
Sculpting
Sculpting Workflows
Modeling Joints
Precision
Hard Edged Modeling
Solid Modeling*
Physics & Modeling
Materials
Creating Materials
Flat Colors
The Material Shader
Bump Maps
The Metal Shader
Refraction
Fresnel Effect
How Materials Work
Complex Materials
Texture Mapping
UV Coordinates
Coordinate Spaces
The Material Tag
All About Nodes
Node Types
Connecting Nodes
Channel Types
Nodes in Depth
Shader Nodes
Texture Nodes
Constant Nodes
Filter Nodes
The State Node
The Instance Node
Math Nodes
Terrain Shaders
Planet Shaders
Points
Planes
Planarity, Coplanar
Vector
Normal
Dot Product
Cross Product
Reflection
Refraction
Fresnel Effects
UV-Mapping
Texturing
Texture Painting
Particles
Workarounds
Faking Volumetrics
Instances
Emitters
Effectors
Lighting
How Lights Work
Lighting Basics
Shadows
Soft Shadows
Reflected Lights
Specular vs. “Real”
Advanced Lighting
Global Illumination
Caustics
Under the Hood
Camera Properties
Shadow Catchers
Animation
Animation Overview
How Keyframes Work
Animation Concepts
Simple Animation
Path Animation
Basic Rigging
Forward Kinematics
Inverse Kinematics
Character Animation
Advanced Rigging*
Physics
Bullet Physics
Physics & Modeling
Physics & Animation
Rendering
Rendering Overview
Environments
Backdrops
Reflections
Lighting
The HDRI Tag
The Radiosity Tag
Realism
Cartoon Looks
Cartoony Materials
Renderer Settings
Baking
Render Manager
The Render Tag
Mocking up a Scene
Nice Test Renders
Product Shots
Interiors
Rendering a Sky Box
Skybox Utility
Managing Complexity
Folders
Smart Objects
Takes
Custom Hotkeys
Custom View Layouts
Quantization
Snapping
Preferences
Render Cache
Script Files
.jas Files
Workflow
Workflow Overview
Points of No Return
Collapsing Symmetry
Rigging & Animation
Morphing
Baking
Importing Stuff
Exporting Stuff
Unity Workflows
Archviz Workflows*
Scripts
Modeling
Animation
Rendering
Particles
Using Scripts
Writing Scripts
Basics
The Console
Appendices
Glossary
Quaternion
Inverse Kinematics
Forward Kinematics
Convex Polygon
Quad
Interpolation
F-Curve
Easing
Keyframe
Texture, Bitmap
Creator
Spline
Sweep
Lathe
Extrusion
Frustrum
Space, Coordinates
Procedural Texture
Image Space
Vector Motion Blur
Normal
Displacement Map
Gouraud Shading
Phong Shading
Box Modeling
Solid Modeling
Tags
NURBS
Render-to-Layers
Glows
Faking Glow
Maximum Image Size
Instrumenting Rigs
Morphing
Network Rendering
Plugins
Image Formats
File Size
Bit Depth
Lossy or Lossless
Alpha Channels
Use Alpha?
Which Way Around?
Premultiplied
3d File Formats
Geometry
Animation
Video Compression
File Size
Lossy vs. Lossless
Faking Motion Blur
Other Resources
Websites
Books
Cheers!
