Destiny
- Messages
- 261
Hi Frank.. very puzzling.. I have never seen that one before... Are you able to it doing right mouse, Open With.. If so, just choose PDF Reader.. ..
A while back I had real issues with an interactive pdf, after the last update.. I read so much on how to fix and found that there were heaps of other with issues.. I finally fixed it really easily..
Check our your Macintosh HD... /Library/Internet Plug-Ins/ .. and if you have
AdobePDFViewer.plugin
AdobePDFViewerNPAPI.plugin
chuck them into your Disabled Plug-ins folder if you do.. Keep them incase you need them later. I did this and it all works fine... Adobe tend to create on update and stuff other things up.. It took a lot to fix this issue... Check the internet out and you will see heaps of issue.. but I have never seen yours... Yours might be a different issue..
Are you able to view any PDF which you download from the internet.. i do not mean an email.. That is different...
Destiny..
Destiny..
The info says "InDesign" - and as I mentioned it seems working just with AcrobatReader.
