Polygontospline script
Joel
Polygon To Spline tip
One important step to remember is to use the Tools — Coord System — Burn transform. In the attached picture, I started with a default cube, then moved, rotated and scaled it. When I dragged it into the "guide target" box per ZooHead, I got the result on the left. After I burned the transform, the spline object appeared where expected, as on the right.
This is my favorite script. Thanks again to Hiroto.
mrfinius
New member
Scripts
Here is what my screen looks like before.....
mrfinius
New member
Scripts
The screen after...... once I insert the cube into the script and then double click. I tried the coord system, burn tool and when I click it nothing happens..
Hope someone can help.
Bruno
frank beckmann
Wrong, wrong, wrong.
As I wrote already in reply N°8 the object goes into "Guide target" like Zoohead shows in reply N°20. Dude - c´mon that isn´t too hard to understand. :D
