project a curve on a surface?
Can a spline or any kind of curve be restricted to a plane, so that even if the plane is crinkled or warped, the curve remains on the plane?
Welcome to the forum, I think this is what you need.
  • Crumple Bend.jas.zip
if it is a simple spline-based / curvilinear pattern you need, the following is also an option:
* generate the graphics in a suitable external application
* apply as a texture to the material of the plane
* apply the required warping modifiers to the plane
Servus from Vienna
Thanks for the tips guys! I'll give them a shot. This is pretty much what I'm looking for:
http://jamie3d.com/projecting-splines-on-a-surface
I just don't want to have to sell the kids to get it :D
It's not difficult to achieve. I used the black colored polygons as a guide and created
the spline from the top view, then quickly snapped the points down with the Transform Tool.
Then choose soft interpolation and moved the spline up, and then a Sweep.
I had a some extra time so I did this one. I used Bend Modifiers on the pill and the 5.
S/shot #1
* load the contour map as a texture and apply
* use the magnet tool to distort the flat plane according to the contour map
* add the pipeline as per Zoohead´s spline plus point snap guide above
S/shot #2
* you may also want to have a look at the displacement modifier
Servus from Vienna
