A script to send ripples thru you
ToddWR
210
a simple wave surface object
http://www.geocities.com/todd_w_r/mov/Ripple.js.zip
boy caustics sure do take a LONG time when added to an animation
its better if the object squares are actual square in shape
other than that have fun and don't forget to add the subdivision modifier to the wave object
happy surfing
Todd
Hi Uncle809us.
That´s strange. It´s working fine from here.
And ToddWR.
That´s incredible. A very cool script. Thought I might need Carrara5pro for this. And cool movies too. Thank you for sharing.
Yes it was a problem on my end.
frank beckmann said:
Hi Uncle809us.
And ToddWR.
It's working now I was having a problem.
Thanks Todd !
Hye,
A very good script, this is very simple to use and create water...
Finish my old bump mapping and so do-it-yourself.
I don't know anything in programmation so thanks a lot for every C3d programmers (I'm just a graphist !!!).
:rolleyes:
Regards...
Hi ToddWR,
Here´s a little loop. Thanx again for the script.
regards
(PS: please play as loop; Format:H264)
  • Pooloop2.mov.zip
Hi Todd,
Great script, but could you tell a little bit more how to use it. I can't seem to add a drop and create a key on the timeline. There's the time setting but what does it do, and how can I add one drop at the time? Thanks again!!!
peer,
sorry about that.
two key frames need to be set up, the only thing needing to be changed is the time parameter. clicking the add drop button alters the wave, click it and the run the time up and down a few times to see the change in the object. the only inital state is the calm water button, so as long as the time parameter changes the waves will update
hope that helps
Todd
wow that looks really nice.:D It's great to see some more scripts. :D
Hi, Todd.
I modified Ripple.js script. please try to use.
* added UV and Size parameter.
* added steps for control drop(s).
* use child object Ball for drop position and amount, if you check 'use Ball'
... pelase check the script file.
Textured Mov. (h.264 716KB)
Caustics Mov. (h.264 1.8MB)
  • Ripple+.js.zip
tg_jp,
thanks, Ive looked it over and it looks good. it is now updated on my site so the original file is replaced. This is what I like about sharing.
hey Martin,
ever thought about including some of the user supplied scripts in a third party folder?
Todd
I'm not such a big friend of that idea since I already get many direct Cheetah3D support questions via email.
If I bundle all these scripts I'm sure that I will also get support questions about them. And I just want to avoid that extra work. Especially since giving support for something I haven't written can become quite complicated and time consuming.
Sorry.
so what would be an unsupported folder, with a big read me file saying that all questions need to be directed at the scripts author instead of Martin.
either way I do understand
thanks for concidering it anyway
Todd
But who reads the readmes?
That's exactly the point. Cheetah3D has a readme file but I think that less then 5% actually read it.
My experience has shown that readme just files doesn't work. For example there are bug reporting guidelines in the Cheetah3D readme file but maybe only 5% of the "crashing" bug reports come with the crash log. So I always have to request it manually by email. :mad:
We have this forum to collect all scripts or not? Maybe a "post once" thread with the scripts could do? So you can post the final script there without replies to it. Maybe the script could be acompanied with a tutorial or movie, but that's all.
edit: Typo
