Administrator
- Messages
- 9,479
Cheetah3D 5.5 Beta 1 (with particle system)
I'm proud to finally release the first beta version of Cheetah3D 5.5. Although it isn't feature complete yet it should be quite usable already. I will write the documentation of the particles system during the beta test so for the first there are just some example files which show how the particle system works.
http://cheetah3d.com/download/Cheetah3D5.5b1.zip
Since this is beta software please don't use it for important work or data.
Here is a list of the new features and the bug fixes of version 5.5.
I hope you like it.
Kind regards
P.S. Cheetah3D 5.5 will be a free update for all registered 5.x users.
-added particle/instancing system
-various particle system types
-particle emitter (omni, rect, disc, mesh and spline emitters)
-particle array
-particle spline
-particle mesh (point, edge, polygon, surface and volume distribution)
-various particle effectors
-dynamic effectors (forces)
-attraction
-drag
-delfection
-gravitaion
-radial
-turbulence
-wind
-state effectors
-orientation
-particles are instanced to save memory
-partcile state node for creating per instance materials
-particle tag to initalize each particle individually
-multiple particles types in each particle system allowed
-many new icons by Frank
-added material preview to material menu
-added many new predefined materials (donated by archie)
-added support for normal mapping
-added Blueprint object to "Object" menu
-added Stair object to "Object" menu
-added "auto" camera light mode
-camera light turns off when there is a light source in the scene or if there is a Radiosity + HDRI Tag
-added Base::scriptPath() function call to Javascript API (returns the path of the script)
-improved joint tool
-added auto-highlighting
-joint hierarchy is expanded by default
-removed context menu from pose tag
-improved turbulence function
-improved split tool (deletes polygon selection)
-integer parameters are now interpolated in F-Curves
-localized object names in object browser
-objects get selected when they are collaps in the object browser
-fixed .jas file loading bug
-fixed some german localization typos
-fixed subdivide bug of second UV set
-fixed bump mapping bug in membrane shader
-fixed crashing bugs in booleans object
-fixed object copy&paste bug
-fixed material selection bug (didn't update timeline)
-fixed bug with material "takes"
-fixed texture tiling bug
-fixed bug when rendering reflectiv objects on bright surfaces
-fixed ESC delete bug
-fixed endianes bug in "File" Javascript class
-fixed crashing bug in rendere caused by NaN-vertices
-fixed bug in joint tool
-fixed pivot point bug in FBX loader
-fixed shadow bug in distant light
-fixed wrongly defined UVPINNED and CREASE constants in Javascript API
-fixed bug in camera navigation icons (jump)
-fixed bug in sweep tool when deleting a spline
-fixed FBX export bug (messed up rotation)
I hope you like it.
Kind regards
