- Messages
- 5,715
Acid - Part II
Ouch! :lol:
Acid - Part II
Hi Zoo: How are you lining up your splines when using the loft script? Do you manually rotate. Until they line up or have you found a simpler way?
The clue I had was from Franks post: http://www.cheetah3d.com/forum/showpost.php?p=6888&postcount=10
Hi unc, most of the time I copy and paste the splines right back in again
and then move it to the next position, but when I add a new spline shape I rotate manually.
Your image explains why it does that, now it make sense.
I also needed a finer mesh to work with so instead of adding a subdivide like I usually do,
which would have made the mesh to fine, I used a smooth modifier.
Acid - Part II
Ah ah ah. Really good. Have you ever tried making a little comic book.
Looks like you've got great ideas and scenarios for this character.
Nice work. Love it.
Houston - we have a problem
the return of the mummy
