Rounded Rectangle
Rounded Rectangle
a, hopefully useful, spline script.
Herbert
Rev 1: Changed radius to absolut instead of relative units on suggestion of Frank.
Rev 2: Added Parameter "Orientation" to select "X", "Y", "Z"
  • Rounded_Rect_0_2.zip
Hi Herbert,
you did it again: cool addition. Very useful.:icon_thumbup:
One thing though to adjust the Radius; is it possible to use units over %? I ask because using arrow keys&dragging is too slow.
Thank you.
Hi Frank,
thought it would be a christmas present for you.
Now: Does your question mean that you prefer normal units instead of relative units, as implemented?
This can certainly be done. In this case I would check internally that the radius is not larger than the minimum of (W,H)/2 and set it back if necessary.
Would this be fine?
Herbert
Hi Frank,
Would this be fine?
Herbert
Thank you.
Then I think I prefer units over percentage.:mrgreen:
As such cracks in C3D find these tools useful, Martin might agree to expose more spline methods to scripting ;)
Thanks to all for the positive echo
Herbert
Hi Gilley,
these are not strange ringcuts, it is just the way C3D cuts a curve when making a parametric polygon editable.
Herb
Hey Herb
Ok, but I want to take the "cover" off. How can i select the whole cover if there are so many divisions?
Thanks for the feedback
gille
Mine´s still working. Your´s look like the rectangle coil.js script with 1 turn.
You´re not the only one. I´m not sure where the "RoundedRectangular.js script came from. The "Rounded_Rect.js" still works here.
