Basic question about user-defined texture wrapping
I'm wanting to be able to wrap my own images around some basic shapes. For cylinders this is easy - I place my design in a rectangle with the width = the circumference of the cylinder, and the height, well, = the height. Load it in, and it works exactly as I want. But when I do this for a cube, I get the texture pasted onto *each* face of the cube. I don't want this - I want to be able to wrap the one texture/image around four faces of the cube and I want the top and bottom faces to remain uniform (for that bit I can probably paste in appropriate occluding shapes in drawing package; that worked well for the cylinders).
Either:
1. I need to figure out how to make the texture 'wrap'. (And I would like the main part of the image to centre on a vertex (i.e. with the cube set on the diamond, as tilers would say). In general, I see no options for this approach. Or:
2. I need to figure out how to paste textures onto individual faces, and start with four texture panels instead of the one long one. Perhaps there is a way of deconstructing a cube object into its faces - pasting in the images - and then joining them back together again. Dunno.
Can anyone help?
To make it short - all this can be done with tools "under" the hood - so you need to dig a bit deeper:
1: Go in UV Editing mode - make your object editable - select individual polygons and look where they appear.
2: Select a polygon and drag a material onto it - that´s all it takes. Adjustments can be done in more than one way.
Find the UV mapper and its flat-projection on selected polygons and so forth.
Sooner or later you´ll have to go for "pinning points" while your loaded image is "editable" and setting seams for unwrapping a row of polys as you may want - and more.
Or best could be to take a plunge into and have a play with example files - best way to learn.
Either:
Can anyone help?
If you're using the UV mapper there's a checkbox that will let you only apply it to the selected face...
My guess is you would have to toggle the seams of the box like this. Unwrap UVs and move the material in the right position.
Terry
  • box.jas.zip
