I just can't get the froth.tif to cast a shadow on the plane1 object. I hope you can tell me what I'm doing wrong, so confused....peer said:Post your scene, and I'll have a look at it if you want
Regards,
Peter
uncle808us said:I just can't get the froth.tif to cast a shadow on the plane1 object. I hope you can tell me what I'm doing wrong, so confused....
Francois said:uncle808us,
Here is the answer :
- Change the shadow type of the spotlight to raytrace + transparency
- You need to use an 8bit/channel image rather than a 1bit/channel. I'm not too sure why but Martin may need to look at this.
I loaded the froth.tif image with Apercu and then did a "Save as..." with 8bit/channel. And this is now working...
Here's the worm with the shadows.uncle808us said:Spotlight raytrace+transparency DUH!! man sometimes I wonder, I should have known that. Thanks to the both of you. I upload the result of my project when it's finished. Thanks agian.
uncle808us said:What is :Apercu
frank beckmann said:Huh.
If this is living underneath the Ypenhof Villa.........
Cool beast.
