Jake
HDRI
Here's the HDRI I used in the Fallingwater render, but at a much lower resolution. I've been trying to light building exclusively with HRDI's, but there is a lack of light on the bottom surfaces. What I have done, thanks to Tim's questioning why black, is use a lighter neutral gray along the bottom. of the HDR. This will give you the clouds and illumination from above and some fill light from below, depending on how you models is constructed.
If you are doing close-ups of certain areas that don't include the ground then turn off you ground so it isn't visible and this will allow the lighter portion of the HDRI to light the underside of the eaves etc. Play with the power too. It need to be turn up to 2, so that may burn out the sky image. In that case use the HDRI exclusively for lighting and render with colored background so that you can then strip in a sky later in photoshop. This gives you the best control.
Well I just tried to upload and it was too big. I thought Martin had bumped up the size for attachments. Send me an email until I figure this out and I'll send it along that way.
