Rendering time
Rendering time
Hello everybody,
I modeled a vase yesterday to try and create some materials, but, when I tried to render it, it took 28000 secs to render it up to the point you see in the below image. It's probably just my ignorance, but it seemed a bit strange to me, so here I am :tongue:
Here are my computer specs:
Model Name: MacBook
Processor Name: Intel Core 2 Duo
Processor Speed: 2 GHz
Memory: 1 GB
Bus Speed: 667 MHz
Below you can find the .jas file, too. Thanks for your help :)
  • vaso.zip
You're running into problems caused by choosing lots of slow rendering options which each increase rendering time geometrically.
1. Skylight -- it's very easy to use, produces nice results, but it's SLOW.
Ideally, the skylight will one day be replaced by a procedural HDRI (Cheetah's IBL is quicker than the Skylight). Use HDRI + Radiosity instead -- or a distant light or area light if you want sharp shadows.
2. Blurred reflections with lots of samples.
These two renders took 75s and 177s on my Mac Pro.
As a final aside -- the procedural wood looks horrible. Much better to do some test renders with modest settings before you start tweaking the final render settings.
  • vaso.jas.zip
  • vaso_dist_light.jas.zip
Thank you very much, podperson!
Here's my final result (in 27.35 secs :D)
