selection menu
248
selection menu
I just now noticed the selection menu. These are really cool but I couldn't find any info on the tools in the help document. How do you modify objects selected with the area selection tool? After making a selection, it deselects if I click again to move it. Thanks in advance-Lonestar
sorry you are right. The documentation of the selection tools is still missing. Sorry:oops: I have to change that.
Once you've made a selection with the area select tool you have to go back to the transform tool for example to move, scale or rotate the selection. The easiest is if you define a hotkey (see the Preferences window) for the transform and the area select tools. So you can then switch between these often used tool just by a key stroke.
By,
