rotation.X and rotation.Y switched in the f-curve editor?
It seems to me that rotation.X and rotation.Y in the f-curve editor are switched compared to rotating in the 3d view (coord sys set to object). When I manually rotate using the red axis circle in the 3d view and set a key, it's rotation.Y (green in the editor) whose value gets changed. It's a bit confusing for curve editing. Is it a bug or am I overlooking something?
I've attached a simple example that should make it clear...
