Fix UI Oddities
1) Hidden image file format support
You can currently save renders as png or jpg simply by typing the extension. This should be made explicit via a popup menu (for instance) in the Save dialog.
Ideally it should remember your choice and default to the format you last picked (between sessions even) so that I can always save as PNG.
1a) Allow JPG compression quality to be set.
Enough said.
1b) Ideally, just use QuickTime Image Format options.
2) If you press "command-s" when editing a non .jas file which will not retain all the information in the current file, it should be treated as "Save As..." (which is more Mac-like).
Currently, if you open a model file (e.g. .sia) and add lights to it and then press command-s, it doesn't save your lights and when you close the document or quit, your changes are lost without warning.
Enough said.
