Grid objects
Grid objects
This script will grid boxes of a given scale, so that they all appear in a grid formation :
Code:
var gridXObject="Max Columns";
var gridYObject="Max Rows";
var xScale="X Scale";
var yScale="Y Scale";
var zScale="Z Scale";
function buildUI(tool)
	tool.addParameterSeparator("Grid Object.js");
	tool.addParameterInt(gridXObject,8,1,256,false,true);
	tool.addParameterInt(gridYObject,8,1,256,false,true);
	tool.addParameterFloat(xScale,1.0,0.1,256.0,false,true);
	tool.addParameterFloat(yScale,1.0,0.1,256.0,false,true);
	tool.addParameterFloat(zScale,1.0,0.1,256.0,false,true);
	tool.addParameterButton("Apply","Apply","apply");
function apply(tool)
var y;
var x;
var box;
var obj;
var root;
var doc;
var pos;
var child;
	doc=tool.document();
	root=doc.root();
	pos=0;
	child=null;
	for (y=0; y<tool.getParameter(gridYObject); y++)
		for (x=0; x<tool.getParameter(gridXObject); x++)
			obj=doc.addObject(BOX);
			obj.setParameter("scale",new Vec3D(tool.getParameter(xScale),tool.getParameter(yScale),tool.getParameter(zScale)));
			obj.setParameter("position",new Vec3D(tool.getParameter(xScale)*x,0.0,tool.getParameter(zScale)*y));
			if (x==0 && y==0)
				child=obj;
			else
				if (child)
					child.addChildAtIndex(obj,pos);
			pos++;
Hi MrTAToad.
Thank you for the script. Nice one.
One thing thou. If I scale my box other than 1:1:1, maybe 1:3:0.5 I get one special box. Do you expect this?
No, I wasn't expecting that - I found that it seems to be something to do with the adding to child function.
If you use this instead, it works fine :
Code:
var y;
var x;
var box;
var obj;
var root;
var doc;
var pos;
var child;
	root=doc.root();
	pos=0;
	child=null;
//			if (x==0 && y==0)
//				child=obj;
//			else
//				if (child)
//					child.addChildAtIndex(obj,pos);
			pos++;
Unfortunately you then have to do all the grouping yourself.
I'll see if anyone knows what the problem is (probably using the child function improperly or something). Unfortunately the documentation doesn't help much there.
Unfortunately you then have to do all the grouping yourself. I'll have to find out whether this is a bug in Cheetah or something to do with my code.
Thanks, works fine now. Grouping is just 3 clicks and I do prefer to do that manually, than have one "mother" and a tail of children;-)
With indest regards
Just for the challenge: One can think upon numerically adjustable holes between the boxes?
Should be easy to do a step value.
Okay, here it is :
Code:
var xStep="X Step";
var yStep="Y Step";
	tool.addParameterFloat(xStep,0.0,-256.0,256.0,false,true);
	tool.addParameterFloat(yStep,0.0,-256.0,256.0,false,true);
var y;
var x;
var box;
var obj;
var root;
var doc;
var xPos;
var zPos;
	root=doc.root();
	zPos=0.0;
		xPos=0.0;
			obj.setParameter("position",new Vec3D(xPos,0.0,zPos));
			xPos+=tool.getParameter(xScale)+tool.getParameter(xStep);
		zPos+=tool.getParameter(yScale)+tool.getParameter(yStep);
This generates a gap between each block.
Cool - it´s working. Sorry for one thing thou. Wouldn´t you expect the same gap by the same "step" space?
Thanx again.
Okay - one final update :
First off, there was a mixup with the Z & Y values - that should sort the step problem (although it wont fix the grouping problem with the original scaling values). I've now added the option to just do the borders of the grid, and the option to group the grid.
Code:
// This script is designed to create a grid of boxes of a given scale
// Written by Nicholas Kingsley
var xStep="X Step";
var zStep="Z Step";
var justBorder="Only Border ?";
var groupObject="Group Objects ?";
	tool.addParameterFloat(zStep,0.0,-256.0,256.0,false,true);
	tool.addParameterBool(justBorder,false,false,true,false,true);
	tool.addParameterBool(groupObject,false,false,true,false,true);
var y;
var x;
var box;
var obj;
var root;
var doc;
var xPos;
var zPos;
var process;
var child;
var pos;
	root=doc.root();
	child=null;
	pos=0;
	zPos=0.0;
		xPos=0.0;
			process=true;
			if (tool.getParameter(justBorder)==true)
				if (x>0 && y>0 && x<tool.getParameter(gridXObject)-1 && y<tool.getParameter(gridYObject)-1)
					process=false;
			if (process)
				if (tool.getParameter(groupObject))
					if (x==0 && y==0)
						child=obj;
					else
						if (child)
					pos++;
				obj.update();
		zPos+=tool.getParameter(zScale)+tool.getParameter(zStep);
I do want to get the grouping thing working - that would sort everything...
Okay, I think I've finally got the group positions sorted :
Code:
// Version 1.04 - Fix object size when grouping them.  As child scales are affected by the parent, it seems that we just need to use a scale of 1.0,1.0,1.0
//					after setting the parent scale.
// 					The grouping problem does however affect child positioning if the Z scale!=1.0
//					To get around this, it appears that, as the scale is 1.0,1.0,1.0, we position in increments of 1.0,0.0,1.0
var xStep="X Step";
var zStep="Z Step";
var y;
var x;
var box;
var obj;
var root;
var doc;
var xPos;
var zPos;
var process;
var child;
var pos;
	root=doc.root();
	child=null;
	pos=0;
	zPos=0.0;
		xPos=0.0;
			process=true;
					process=false;
			if (process)
				if (x==0 && y==0 || tool.getParameter(groupObject)==false)
				else
					obj.setParameter("scale",new Vec3D(1.0,1.0,1.0));
					if (x==0 && y==0)
						child=obj;
					else
						if (child)
					pos++;
				obj.update();
				xPos+=1.0+tool.getParameter(xStep);
			else
			zPos+=1.0+tool.getParameter(zStep);
		else
