Material List
What exactly do you mean by "storing"?
Do you mean adding your own materials to the palette of default materials? Or what?
Something like this. Where you don't have to keep making a material over and over.You make it once and save it. You can select it and use it again on another project.
Cool!
You can use a cheetah document as a material library in the interim.
Unfortunately, you can't drag a material between documents.
That´s not true.
Move the first Cheetah window to the right till you might see the the next Cheetah window underneath with you object. Now leftclick&drag your material from the first window onto your object in the second window. Your object will be textured now and the material goes straight in the material browser.
