Hi All,
I'm trying to combine objects and retain their materials so I'm using the boolean tool. But I'm encountering a constant problem where the objects disappear upon application of the tool. It works fine with simple objects, but happens often with custom complex objects. Sometimes I'm able to fix it by moving the pieces but I'd like to understand the root of the problem.
I've attached a project with before and after folders of the objects. You'll see the "after" has the resulting combination object, but it is invisible.
Thanks in advance for any insight.
Terry
Terry
