Somian
I keep running into this problem:
I have an animation that takes a long time to render, so I might need to render it a few frames at a time.
Let's say the animation is 200 frames. I want to render frame 0-60 today and 61-170 tomorrow and then 171-200 the day after.
The problem is that when I do that, the first rendered frames rendered each day will be named "image_00000".
this makes is hard to then combine all the resulting images into a image sequence. I always need to know what render job was what frame range and then rename the images accordingly.
if, for the second render job, it would be named "image_00060", It would be as simple as copying the images together.
