Foil wrap noise spot
Hi I tried everything.
I have a black noisy spot on my render.
How can i remove this?
Thnx Rob
  • foil-wrap.jas.zip
Well i need the background for realistic shadow.
Is there something else to try?
I tried with a regular material, but spot is still there.
Mmmh - still unsure about the result you want to achieve.
Excluding the plane from seeing by the camera via Render-tag will look like this:
I stay here till we get it sorted.
Thanks but not what i need.
The shadow in my render now is noisy or broken.
I like a natural shadow.
I´d try with Falcon then. Give the foil a tiny bit of a thickness and enlarge the plane to fit camera view and add a white diffuse material to it. studio020 is set to Intensity:4 and that´s how it looks like:
But still wondering how this could be done with cheetah 6?
Darkened area behind glas/transparent objects always have been tricky to master - if that´s possible at all. I remember these kind of threads very well - but there´s no instant bliss switch that can be turned on and everything looks as "wished".
Your scene looks more like a proof of concept than a real job - can we if I´m right proceed with a more "lifelike" scenery then?
Yes i'm testing before i can work on this project. I need to make renders of a series of window films. But the focus is on the film. The scene background will be very basic.
I just replicated a transparency from a default material, edited some trans and reflection. looks ok. It seems to be the plastic preset.
Ok - I transferred the file to Cheetah3dv6.3.3 and it turns out pretty well. Let me hear what you think:
I just shrunk it down for the forum.
  • foil-wrap 4 Cheetah3d6.jas.zip
