Change tangents question?
3,687
If you change the tangent in the animation drop down does it change it for everything in the animation all parts?
Is there any way to lock the animation tangents in say, spline? Example: If I have everything set (start and stop keyframes) like I want, then decide that I want to change the end frame position slightly, all of the spline tangents for that frame are erased, and I have to start over. So much extra work! Thanks!
Try this one: Don't move the object itself and re-keyframe.
Instead move the xyz points on the F-curves.
That will keep the splines tangents.
Happy to help.
As long as you don't re-keyframe that frame it keeps the tangent info.
Yes, I see. Im doing it right now. A different way to position, but I'll get used to it. Thanks again!
