Ball-arm constraints - Tutorial?
Can someone possibly point me to a video or tutorial on IK constraints in C3D...? It has been (literally) over 20 years since I did *ANY* IK work, and that was in Lightwave. I just want to take a solid model of a ball-arm joint and apply constraints to the L-Rod... so that it can FREELY move 360° on its heading, but constrained on the other two axis by -42° to +42°.
I tried it on my own quickly and was getting frustrated. Any links would be appreciated... thanks.
This is the REAL object...
And this is a low-effort approximation until I can figure-out the IK constraints...
I'm not sure I'd use any constraints on it - just make sure the pivot-point (set via pivot-mode) is in the right spot.
It seem like this is an orthopedic implant, so I guess you wouldn't
want the ball/rod to twist, so some constraint is helpful.
I used a parent constraint tag to constrain twisting.
The target of the tag is a folder.
  • BallinSocket.zip
It’s actually a drum (tom) mount... and the reason I want to put constraints is because I want to use C3D to “virtually” setup a drum kit, but I want the L-Arm tom mounts to reflect what’s possible in the real world. Ultimately, I will also be adding a drum to each L-Rod, so the drum will be restricted to ONLY moving UP & DOWN the L-rod and rotating along the shaft... but the Ball will be free to allow me to position the drum wherever I need it while I LOCK the vertical mounting shaft in a plumb orientation.
Not sure if I said that right...
Similar to - but not exactly like - this drum mount...
The VERTICAL post stays stationary... the L-Rod affixed at the ball-arm is free to rotate with SOME constraints... the drum can move UP AND DOWN the vertical bend of the l-arm as well as rotat around its circumference.
Boy was I on the wrong track.​
Glad you were - was thinking about the butterfly nut inside a body - made me nervous.
I´d still skip the constraint tag. I´d add the drum to the pivoting rod (hierarchical) and got to go.
This seems to work well.
  • BallinSocket02.zip
