Learning UV Stepper.
Hi: I'm learning to use the UV Stepper and I am having a problem I select two points then I try to use the Stepper to align then horizontally (u) but when I hit align the points shoot way off the uv window. What am I doing wrong? Wouldn't you know it the very first apparently simple operation I screw it up. I tried to learn this all day by using these Links:
https://www.youtube.com/watch?v=jlfVwks56yw
https://www.youtube.com/watch?v=Y0azS2aylDg&feature=youtu.be
https://www.youtube.com/watch?v=zxBY-gq9Qk8&translated=1
Thanks for any help.
I´m not sure I can help as I didn´t use this script very much and can´t read the text+labels on the GIF very well.
Maybe post your question in the original script thread and Hiroto can give you a clue.
Thanks Frank. I have sent a communiqué. to TgJp.(Hiroto).
Thank you I know it's probably user error.. But I'm trying to figure this out.
I don't understand how alignment works I'm trying to get the two points of the box aligned Horizontally.
using UV stepper I know how to use the gizmo and scale to align.
  • TestAlign.zip
Hello,
Thank you for your file. Could you send a file before that execution? before clicking 'alignmnet h' button.
Best
Hiroto
Here is before and after it seems to take the two top points and move them off the UV window to the bottom.
  • Before and after.zip
hello,
thank you for your file. but I couldn't reproduce that bug with your file.
other functions ( move / scale / rotate etc.. ) works?
Best
Hiroto
Thanks for taking the time to address my problem.
It seemed to have fixed itself.
After doing what Frank suggested:
I believe you have to click first get angle then the align button.
From Frank Thanks Frank
BTW: I think that C3d 7.3b2 has the UV Mapper in preferences Keys as ~ already in there, I could be wrong.
I apologize for using up your time on what was probably a user error.
I have to admit I don't understand how to use the UV mapper although it seems like a very useful script.
Unfortunately I only speak and read one language and I don't know of a way to translate youtube videos.
Again I am sorry for using up your time I know you are busy.
