Platelets
Platelets
Hi
I need to model a set of "Platelets" I tried several times but no good result, can somebody help me out, I am stuck! THX
128616999
While this could probably be done in C3d, it may be easier to do in a sculpting application.
Have you tried Sculptris? It's free and I think will output an .obj file.
http://pixologic.com/sculptris/
I'm not sure which ways you already tried to model this in C3d though or I'd give some feedback on the way I'd do it.
Edit:
Also, are these just for still renders, or are you going to animate them?
3 ideas:
- sculptris or similar (as swizl says) - sculptris is for-pay now with zbrush -I'm unsure if its still available for free.
- get close via modelling in C3D, subdivide a lot, use C3D's brush tools
- experiment with Isosurface creator and metaballs
hopefully this was useful.
--shift studio.
I had a quick go with splines+isosurface-creator, made editable add a subdiv-mod and use the brush tools for the "anamorphic" look:
I found some old stuff. Maybe you can use it as a basis.
  • ThromboCyte 0822.jas.zip
