Image Reduction for Forum Posts
Jeanny
1,273
Image Sizing for Forum Posts
IMHO: Sometimes it makes for an easier read and understanding of the problem
if the image posted is a bit smaller.
In the same token sometimes the image needs to be larger . . .
especially if the text is too small to read when the image size is reduced.
Just in case anyone needs to know how to make images (PNG, JPG, TIFF . . . etc)
that they want to post to the forum smaller or larger this may be done in the macOS application 'Preview'.
I’ve listed the steps below.
1 Open the image (file. document) on your desktop.
2 In the Apple Main Menu choose Tools > Adjust Size.
3 In the dropdown adjust the size.
Usually I find the easiest way to use the drop down is use Percent.
  • Make sure Scale proportionally is checked.
  • Change the Width percent numbers to the degree you want the image size to change.
  • (because Scale proportionally is checked the Height will follow suit).
4 Test the results or confirm your choice by clicking OK
5 If the size isn’t to your liking undo (Command + Z) and repeat steps 1 thru 4.
My Best
Jeanny
Hi Jeanny.
Nice post!
I think its not clear however that you are talking about using the macOS application 'Preview'. The tutorial reads like this may be done in the Finder.
--shift studio.
:icon_thumbup: Good call Shift!
Thanks for bringing it to my attention.
I’ve made a few changes in the Tut.
Hope it reads better now.
If there is a better way to express it please let me know.
My Best
Jeanny
One thing you can do is check the properties panel while the object is selected, but if you're trying to match an existing asset or just need to double-check a bunch of textures quickly, I sometimes use this image dimensions finder in my browser. It's a lot faster than opening every single file in Photoshop or an external viewer just to see the resolution.
