Cheetah3D 7.1 Beta 3
after the dust of the v7 release slowly settled it's time to start the beta test of the upcoming Cheetah3D 7.1. The following 7.x updates will focus on smaller features which I wanted to add since quite some time. There are many low hanging fruits in Cheetah3D which I want to pick in the following months. That also has the advantage that I can release 7.x updates on a more regular basis and release bug fixes and new features faster.
New features in Cheetah3D 7.1:
Changes in Beta 3:
Attention:
Download link of Cheetah3D 7.1b3:
http://www.cheetah3d.com/download/Beta/Cheetah3D7.1b3.dmg
I hope you enjoy the new features in Cheetah3D 7.1.:smile:
Kind regards
Code:
-added mesh simplification tool (using fast quadric mesh simplification https://github.com/sp4cerat/Fast-Quadric-Mesh-Simplification )
-added Loft creator object
-added normal compression to Cheetah/Falcon (saves a lot of RAM)
-added scroll wheel support to movie player in renderer manager
-improved Text spline object
-added multi-line support
-added font size property
-added text alignment property
-added character and line spacing property
-added animation property
-improved SVG import
-improved import of densely packed path tags
-arcs are no longer tesselated but converted to splines
-improved spline tesselation algorithm
-more evenly spaced
-3x faster
-improved lathe, polyplane and sweep objects (uv coords to covers)
-improved transform gadget (handles are easier to pick)
-imporved numerical precision of polyhedra object
-imporved numerical precision of ruler tool
-improved performance of material preview rendering
-improved FBX exported/imported (joint type gets handled properly)
-fixed bug in STL, OBJ, 3DS, etc. exporters (subtract with boolean modifier caused problems)
-fixed bug when entering negative values in properties editor (under Swedish language)
-fixed bug in transform tool (IK failed under certain conditions)
-fixed transparency bug in Cheetah
-fixed transparent shadow bug in solid shader
-fixed menu update bug when working with multiple scenes
-fixed document save bug when renderer was changed
-worked around a redraw bug in High Sierra
-updated some sample scenes
Changes in Beta 3:
Code:
-updated documentation
Attention:
Kind regards
