Use HDRI- and Sky-Light simultaneously?
Filip
115
It seems like I'm unable to use them at the same time (when rendered).
Am I experiencing a bug or is it suppose to be that way?
I guess you are referring to Cheetah3D 7. In Cheetah3D 7 you can only use the sky light or the hdri light. But you can't use them simultaneously.
Both light sources are environment lights so it doesn't make to much sense to use both lights in the same scene. There is just one environment in real life.
If you have multiple active environment lights in your scene Cheetah3D will use the one which shows up first in the object browser.
Bye
If you want to keep reflections from the HDRI and harsh light shadows you can add a Distant-light source instead.
This helped me!
I was just now trying a starry hdri map which doesn't illuminate objects very much, so the distant light did the trick.
Just info - we can now have soft shadows with the distant light and some other light sources in Falcon.
