Localising bone rotations
Hi Cheetah folks,
When I make and bind a skeleton, I notice all my bone rotations are zeroed. Meaning a bone in a rotated position is regarded as being set at rotation 0,0,0.
Is there a way to set them to true rotation? As in not move them but have them reflecting their true rotation?
You can see in this image, if I had access to true local rotation it would be easier to animate wings opening and closing. Having only world co-ordinates makes for a challenging task all of a sudden.
What are workaround suggestions?
Aaron
How would you make bones curl, as in a finger situation?
I've seen in other apps, you select all the bones and rotate and they rotate in a curling motion.
Bob
Orient Joint tool doesn't seem to work properly in latest v7 build...unless I'm doing something wrong.
If I choose the root bone, call up Orient Joint, click the Hierarchy button then OK, only the first two joints seemt o be oriented the same way. The others are at random rotations.
Bob
