clone problem
clone problem
Hello!
I would like to clone a part of an object but i have a problem.
If i give a value of the y direction that is bigger then zero, the clones are appeared, but not on the same hight then the original one.
My plan is to rotate the clones on y without y direction, that is why i gave zero. In this case there was't any rotation, clones were placed right on the place of the original polygon.
What is the solution?
thx, Robert
The Ring Modifier will do what you need.
Either cut the whole object up or split the
piece you want to copy into a new object.
