Wow thanks Frank, A quick way of doing this is by parenting objects. I've attached a movie but I think the one on coordinates in the tutorial section of my site says the same thing.Hi.
I´m quiet sure that there is another way, but till Andrew will show you the trick, you can try this.
off topic... but since i am relatively new to the amazing world of mac...
What's the application you use to make those movies in real time from screen?
thanks,
-t0m
Hi.
I´m quiet sure that there is another way, but till Andrew will show you the trick, you can try this. Place your door where the hinges are over zero xy axis. Then go "tools - coord system and burn transform. Move back your door and now it will open from the hinges.
And now ......
Hi Frank
I tried this but it didn't seem to work. When I hit burn transform I get a sort of error sound and nothing happens. Any idea what I'm doing wrong?
