Normal Move as a Modifier
I'd like to request a Normal Move modifier.
It would be like a 'Shell Modifier' but moves a mesh along a positive normal direction.
Possible?
Thanks, Shift Studio.
I'd like to ask for this again and for it to be able to take a negative number (or possibly include a normal flip)
Thanks for considering!
--shift studio.
At least you can try the "Morph-tag" to record the normal move:
I think the envisaged use-case was as part of a modifier chain, which makes the morph trick less useful.
This is something that could be implemented as a script.
--shift studio.
There is a trick to achieve that:
Adding a transform modifier with scale values -1/1/1 will flip the normals of an object, even a parametric one, wich is useful for terrains or having a cam inside the box etc.
Adding the crumple modifier (frec.0) then will move faces along the normals in the opposite direction.
To restore normal orientation another transform modifier with -1/1/1 scale is needed.
Fun fact: transform gizmo turns dark :tongue:
I find the morph-tag works quite well in conjunction with a modifier chain:
you three are right - I am thinking to use the proposed modifier in a modifier chain.
I'll give both a try. Missoversaturated, yours appeals to me more as I'm less familiar with the morph tag though.
Now for the wish, the functionality in one modifier.
--shift studio.
