Cooking up a Moon
Cooking up a Moon
With the recent posts and tutorials on heavenly bodies. I thought I'd add a tutorial that's a bit different.
This tutorial shows you how to cook up your own moon surface in your kitchen. By the end of this tutorial, you should have a rendered image that looks something like this:
Part 1 - Cooking Pancakes
Cooking pancakes is a weekend tradition at home. With all the bubbles that form on the surface of the pancake as it cooks, I have often wondered how well this surface would work as a bump map.
In this tutorial, we will be cooking some pancakes, scanning them, creating a bump map, and applying the bump map to a sphere.
Enjoy!
I prefer eating mine with lemon and sugar, but you may prefer maple syrup.
Part 2 to follow...
Part 2 Creating a Texture and Bump Map
Here are the steps for creating a texture and bump map. If you use Photoshop or Pixelmator for this, the steps will be different, but hopefully you will be able to replicate the results.
Part 3 - Setting Up Your Moon
I have kept this as simple as possible. Hopefully you will give this a try, come up with better renders, and share your settings.
Here is a zip file with the cheetah file, background image, texture and bump map files: moon files.zip
For anyone who wants the original scanned pancake, here it is: scanned pancake
Great technique with beautiful results.
Thanks for an excellent tutorial. :icon_thumbup::icon_thumbup:
Thanks Eric
Here's a simple animation. The movie was rendered in Cheetah 3D, then imported into PicGIF and exported as a smaller gif.
Love it. Perfect. I know there was something I took these photos for:
:p Never found the time - glad you did.
PS: here´s a quick go with a cage transforming on the pancake - I guess I´d find a rectangular pan next time:
I wonder if you could replace the manual painting step with some layer magic… You might also apply the material as a displacement map to the underlying geometry.
With all these left-over pancake images, I think we may have to start a competition to recreate a plate of 3D pancakes!
This is now too easy: grab disc-object • add subdiv+shellmodifiers • make editable - use UV-mapper to align image texture in flat projection - use new brush-tool in push&pull mode to add some varieties at the edges • copy&paste&rotate&stack some copies • done:
:D Thanks for the very informative and fun tut Chris! Bet you have some happy fat birds in your back yard.
In my attempt to try using pancake images to create a moon surface i found this amazing image of a pancake made to look like Spock. Thought it would be an appropriate and fun image to use to test making a "Man in the Moon" bump mapped moon texture.
I think it makes a cool moon bump map. . .
Never-the-less; Besides not being gifted in a photo editing app to make deeper craters, I find: even as hard as I've tried for the last several days I can not get my material mapped around the sphere correctly.
The back of the moon shows a seam line.
Thus . . . I'm throwing out the following plea:
What on the heavenly body Earth am I doing wrong about trying to map my image on the ball representing the earth's heavenly body Moon?
I've tried the uv mapper as well as the regular uv mapping editor.
@ Frank: I see you used a "Cage transform" with the uv mapper . . .
Would you explain where that is and how you used it?
I've included my .jas file and images in a zip file.
Right now I"m going to my kitchen to see if I can rival Frank's pancakes.
My Best 2U
Jeanny
  • Spock Moon 3.zip
When you look at the default UVs of a sphere in UV-editor you´ll notice the need of a square or rectangular image. When there´s a a visible seam your texture isn´t seamless where you put Spock on. So better get a seamless pedant and put Spock on this one.
The pancakes are circular because of my round pan and the UVs of the ball are square I used the cage deformer tool in GIMP to stretch the image quadratic. (no - it´s not seamless by default.)
Here´s to an tutorial on making seamless textures from any image: http://www.cheetah3d.com/forum/showthread.php?t=1555
Thanks for the information Frank. It's late and I'm going to study all the info tomorrow.
Looks like there is a thank you in order for Podperson also. . . Thanks Pod.
My Best 2U
Jeanny
Thanks Jeanny
I'm glad you like the tutorial. I didn't create a seamless texture, so I'm sure I have a seam as well. I was after a still shot originally, so I wasn't worried about a seam at the time.
@Tonio. I'm not sure what layer magic I can do to deepen the craters. I think the difficulty is, the contrast in the pancake's colours relates to the heat when cooked and not shadows; hence having to enhance the depth of the craters manually with a brush.
When I get back onto my Mac, I have a few things to follow up:
- working out how to make my pancake texture seamless in Afffinity Photo
- trying the displacement map (thanks Tonio) approach, and
- building a virtual stack that rivals Frank's.
Thanks to everyone who left a comment. It's Sunday tomorrow, which means pancakes for breakfast!
