Math extension
I am working on a math extension that is appropriate for things you may have to do when working on 3d files. So far it is minimal as you can see in this post. I am also keeping a version on pastebin. If I ever grow up and use GIT, I'll provide a link to that. But until then you've got this paste at least:
____
Even though we don't have require we do have the use of eval, and thus a file like this can function as an include. Here's a link to how I am doing this. Others were the smarties and came up with this sneaky work around. I'm just sharing with you.
Code:
// math_extension.js
2015 march 15
v 0.1
-- extending Math for use in 3d app
converts radians to degrees and vice versa
converts eulers to axis-angle and vice versa
// EXTENDED MATH FUNCTIONS
// Converts from degrees to radians.
Math.radians = function(degrees)
return degrees * Math.PI / 180;
// Converts from radians to degrees.
Math.degrees = function(radians)
return radians * 180 / Math.PI;
// Converts from Axis Angle in radians to Euler in degrees
Math.AxisAngleToEuler = function(x, y, z, angle)
var heading,attitude,bank;
var s=Math.sin(angle);
var c=Math.cos(angle);
var t=1-c;
// if axis is not already normalised then uncomment this
// double magnitude = Math.sqrt(x*x + y*y + z*z);
// if (magnitude==0) throw error;
// x /= magnitude;
// y /= magnitude;
// z /= magnitude;
if ((x*y*t + z*s) > 0.998)
{ // north pole singularity detected
heading = 2*atan2(x*Math.sin(angle/2),Math.cos(angle/2));
attitude = Math.PI/2;
bank = 0;
else if ((x*y*t + z*s) < -0.998)
{ // south pole singularity detected
heading = -2*atan2(x*Math.sin(angle/2),Math.cos(angle/2));
attitude = -Math.PI/2;
bank = 0;
else
heading = Math.atan2(y * s- x * z * t , 1 - (y*y+ z*z ) * t);
attitude = Math.asin(x * y * t + z * s) ;
bank = Math.atan2(x * s - y * z * t , 1 - (x*x + z*z) * t);
return {'x':Math.degrees(bank),'y':Math.degrees(heading),'z':Math.degrees(attitude)};
// Converts from Euler in degrees to Axis Angle in radians
Math.EulerToAxisAngle = function(bankDegrees, headingDegrees, attitudeDegrees)
var Xradians = Math.radians(bankDegrees); // bank
var Yradians = Math.radians(headingDegrees); // heading
var Zradians = Math.radians(attitudeDegrees); // attitude
// Convert Euler to Axis-Angle
// NWN appears to use an axis angle
// downloaded from http://www.euclideanspace.com/maths/geometry/rotations/conversions/eulerToAngle/
var c1 = Math.cos(Yradians/2); // heading
var s1 = Math.sin(Yradians/2);
var c2 = Math.cos(Zradians/2);// altitude
var s2 = Math.sin(Zradians/2);
var c3 = Math.cos(Xradians/2); // bank
var s3 = Math.sin(Xradians/2);
var c1c2 = c1*c2;
var s1s2 = s1*s2;
var w =c1c2*c3 - s1s2*s3;
var x =c1c2*s3 + s1s2*c3;
var y =s1*c2*c3 + c1*s2*s3;
var z =c1*s2*c3 - s1*c2*s3;
w = 2 * Math.acos(w);
var norm = x*x+y*y+z*z;
if( norm==0 || norm <= 0.0001)
{ // when all euler angles are zero angle = 0 so
// we can set axis to anything to avoid divide by zero
x="1.0";
y=z="0.0";
else
norm = Math.sqrt(norm);
x = (x/norm);
y = (y/norm);
z = (z/norm);
return {'x':x,'y':y,'z':z,'w':w};
____
