Cheetah3D cannot read its own files
Wrote a script, produced three nice pictures in ten hours, saving the files and then finding, that Cheetah3D could not read the files it wrote.
Can anybody help?
Find attached the script that is the culprit for the disaster.
herbert
Can anybody help?
herbert
function buildUI(obj){
obj.setParameter("name","Arrow2D");
obj.addParameterFloat("length",1,0,1000,true,true);
obj.addParameterFloat("L_of_head",.3,0,1000,true,true);
obj.addParameterFloat("diam_of_shaft",.1,0,1000,true,true);
obj.addParameterFloat("diam_of_head",.25,0,1000,true,true);
obj.addParameterInt("axis",0,0,2,true,true);
obj.addParameterBool("rot",false,false,true,true,true);
obj.addParameterBool("double",false,false,true,true,true);
obj.addParameterBool("reverse",false,false,true,true,true);
function buildObject(obj){
var arrow=obj.core();
var i;
var x,y,z;
//get current parameter values
Length =obj.getParameter("length");
L_of_head =obj.getParameter("L_of_head");
diam_of_shaft =obj.getParameter("diam_of_shaft");
diam_of_head =obj.getParameter("diam_of_head");
axes =obj.getParameter("axis");
rot =obj.getParameter("rot");
doubl =obj.getParameter("double");
reverse =obj.getParameter("reverse");
var x1=diam_of_shaft/2;
var z1=Length/2-L_of_head;
var x2=diam_of_head/2;
var z2=Length/2;
var NrOfEdge=7
if (doubl) {NrOfEdge=10}
var points = new Array;
if (doubl) { points.push( new Vec3D(x1,0,-z1) ); } else { points.push( new Vec3D(x1,0,-z2) ); }
points.push( new Vec3D(x1,0,z1) );
points.push( new Vec3D(x2,0,z1) );
points.push( new Vec3D(0,0,z2) );
points.push( new Vec3D(-x2, 0,z1) );
points.push( new Vec3D(-x1,0,z1) );
if (doubl) { points.push( new Vec3D(-x1,0,-z1) );} else { points.push( new Vec3D(-x1,0,-z2) );}
points.push( new Vec3D(-x2, 0,-z1) );
points.push( new Vec3D(0,0,-z2) );
points.push( new Vec3D(x2,0,-z1) );
var i;
if (reverse){
for (i=0; i<NrOfEdge; i++) {
reverseP(points);
if (rot) {
flip(points);
rotate(points, axes);
arrow.move(points[0]);
for(i=1;i<NrOfEdge; i++) {
arrow.line(points);
// arrow.close();
arrow.line(points[0]);
function rotate(pos, axes){
var posi=new Vec3D();
posi.x=pos.x;
posi.y=pos.y;
posi.z=pos.z;
if (axes==1) {
pos.x=posi.y;
pos.y=posi.z;
pos.z=posi.x;
if (axes==2) {
pos.x=posi.z;
pos.y=posi.x;
pos.z=posi.y;
function flip(pos){
posi.x=pos.x;
posi.y=pos.y;
pos.x=posi.y;
pos.y=posi.x;
function reverseP(pos){
posi.z=pos.z;
pos.z=-posi.z;
