John B
Another Beginner's Mapping Question
I'm new to Cheetah 3D but not 3D modeling (used Strata, Cinema 4D, Unity, and others). I've spent my first several hours just trying to get a material mapped onto an object. Unsuccessfully.
As you can see in the attached image, I can't seem to get a texture to cover an entire object, in the attached sample, two cubes with a bevel on one side. I made a cube, created a texture, and applied it to the cube. That worked, all six sides had texture on them. As soon as I add a bevel, one or more sides go blank. I've spent over two hours trying every possible UV setting and manipulation, but nothing I do will put a texture on those blank sides. I've deleted, recreated, and added the texture many times.
Obviously I'm missing something as this should be about the simplest possible thing to do. So my first attempt to actually use Cheetah has failed at step 1. Please help.
