Yosemite / Catmull Clark
I experience the problem that the tool panel for Catmull does not show up under OS X 10.10. The Catmull works, the panel is gone :confused:
I am quite sure that there was an option to switch Catmull-Clark <> Stam-Loop and to define the levels of the required subdivs. It may be possible that the "good Doctor" dumped this in C3D version 6.3.1 for whatever reason (I was on a short break from Cheetah 3D due to other IT work and may have missed that).
Does anybody who uses Yosemite have identical problems?
Greetings from Vienna
PS: Even if you don´t use Yosemite, do the Stam-Loop / levels options still exist in C3D 6.3.1?
Thank you
Thank you
Sure - no change.
Thank you Frank
In my case, there simply is no properties window for Catmull. I have the properties window for - see trivial example - the original box but nothing else.
Sigh :frown:
Überstunden am Samstag ??? Danke aus Wien:tongue:
Thank you Frank
Sigh :frown:
Strange. Martin should open a thread for Yosemite related bugs. ;)
Jep - und das bei fast 30° im Atelier. :shock:
PS: Oops; are you talking about the Subdivsion-Modifier right now?
Not the subdiv modifier, just the Catmull tool.
As to the temperature in Hamburg: An extraterrestrial Pömpel (which we Austro-Bavarians have to look up in the Duden / Wahrig / or possibly Grimm) removes hot air in a breath-taking whiff. Be aware of lethal side effects:frown:
Servus from Vienna
On innocently opening the Guardian website I now get this :rolleyes:
Pömpels and adverts for St Pauli ???
Coincidence or paranoia? Is there a doctor in the house?
PS: de:Freudenhaus = en:brothel
