Render Wireframe and object
24
Hi, I was wondering if there is a script that could render an object and show the wireframe and polygon points. I think that Silo 2.3 does a pretty cool looking wireframe/polygon mesh. I'm trying to achieve a very minimalist look.
-Sam
I don´t understand what you´re asking for. What´s the difference here:
If you want to render it you need to make a material:
Add Default > Material and go to the Node editor
RMB Add Node > Textures > Wireframe
In Wireframe change Color 0 to white and Color 1 to black
Select Color output in Wireframe and drag it to the Transparency of Material
Set Specular to black and Index of refraction to 1
Apply the Material to the mesh and adjust the Line width
Exactly!
thanks guys for the lovely feedback!
Frank this post:
"Bounding Box" won´t work for you?
is exactly what I wanted. Thank you!
and also, pjedvaj, thanks for this material tip. I'll make sure to try this too!
Best,
-shmambu
Let´s see what user shmambu had in mind.:p
Actually, frank what I really wanted was to be able to render something as Bounding-Box. Not just in the editor, but post-render too.
Let me know if this is possible. I'd love to know!
Thanks,
-shmambu
