Thanks for your example Rene66. Your technique demonstrates a far better understanding of the tools. However I believe we are arriving at the same place. To get to my specific concern, look at my video & yours. Notice the details in the ocean areas. When the ocean begins fill up with water, the details of the bathysphere disappear.
This is apparently due to the gradient position change. When the gradient reaches the end of it's ramp, there is no more transition of color - the tonal details are lost. From what I understand, from what I see, there is a need to modify the gradient stops over time to achieve the subtle transitions and render at least some of the bathysphere tones.
This may be a small road, but I believe it would lead to a pleasing result... if I could keyframe a gradient change! I still don't see how I can achieve the desired result with the current set of tools.
I'm fairly sure I could do this in Photoshop, but it would require some major scripting, and several steps that included tones, colors & masks. Along with having to extract each MOV rendered in C3D into individual PNG's, do the PSD magic and re-animate the results, it's a bit of work and would be a specific one-time script. Perhaps there IS a need for gradient modifying in a keyframe and I should officially make-a-wish.
I have a some more issues that this brings up and hope to use this project to resolve them as well. I want to carry this specific issue to it's conclusion (if possible) before I open up other concerns. So I will give this a chance to go a few more days, then throw in the towel if necessary, make-a-wish, and move the next issue. Technique is everything! I'm learning as I go - with a little help from my friends
Thanks again,
Jeff
