Node Editor - invert
wal3d
714
I'm looking for a Node in the Node Editor to invert a texture map.
I couldn't find one. Is there a possibility to create one?
Wolfgang
the SUBTRACT node (in the Math category) will do the trick.
• Create a new material - in the Node editor, create a new IMAGE & SUBTRACT node.
• Set the "A" value in the SUBTRACT node to "1.0"
• Plug in the "Color" from your IMAGE node (that has the height map loaded) into the "B" value of the SUBTRACT node.
• Plug in the the "Val" of the SUBTRACT node into the "Bumpmap" of the MATERIAL node.
done :)
Hi Rene66.
Thanks a lot ... I will try this out! :wink:
I'm wondering how you can figure this out ... :rolleyes: ... but anyway ... hopefully it works! :D
Thanks again,
Wolfgang
We learn by playing around with things - and reading posts on the forum. This inverse trick I learned from a post by Podperson.
With the nodes, it's all math I have discovered and Colors are like percentages: 0.0 = 0%, 0.6 = 60% and 1.0 = 100% etc.. In this case we're dealing with a bump map which is grey scale 0.0=black & 1.0=white.
If a pixel on your bumpmap is 67% grey and you need the inverse (33%) - using the SUBTRACT node gets you there.
(A)1.0 - (B) 0.67 = .33 (33%grey)
Hope that helps clarify what's happening with this "trick" - Continuing playing
Hi Rene66.
I used the technique to invert an external gradient map and it works very well with it as far as I can see. :icon_thumbup:
I'm not sure that I can handle it with all kind of image maps, but we will see.
Thanks again,
Wolfgang
A color image map can be inverted by subtracting from 1.0 in x y and z (which act as R G and B).
You can also brighten, darken, increase contrast, and -- if you're clever -- apply gamma correction. If you want to apply "curves" you can create a black-to-white gradient in Photoshop, apply the curve to that gradient, and then use a slice of that image as a "look up table" (if you're interested, I can post more details on this).
It's all arithmetic or a little algebra.
E.g. brighten an image, use an add node to add a small amount (e.g. 0.1, 0.1, 0.1) or add a color (e.g. light gray). To manipulate contrast, subtract 0.5, 0.5, 0.5, and then multiply by a number (1.0 has no effect; 2.0 increases contrast, 0.5 decreases contrast), and then add back 0.5, 0.5, 0.5.
(You'd be shocked at how simple most of the things Photoshop does are at a pixel level — my favorite discovery from a paper on this stuff was that sharpening is done by blurring an image and then subtracting that image from the original (!). Think of it as Sharpened Pixel = Original Pixel x ( 1 + epsilon ) – Blurred Pixel x epsilon. If you use a matrix blur you get crude sharpening, if you use guassian blur you get unsharp mask.)
So you´re saying you can invert a colored map with the subtraction-node? All I see is inverted brightness not inverted RGB-values here.
I´m used to use another approach to invert colors. Just curious. ;)
Yes that's exactly what I'm saying.
E.g. red: 1.0, 0, 0 inverts to 0, 1.0, 1.0 (cyan).
Edit: added example showing invert, brightness, contrast, and curves (!) using C3D nodes.
  • node image filters.zip
Yes, very cool ... thanks a lot!
I see I have to play around more often with the node editor! :p
Hi everyone
Podperson or anyone.
Are there math node equivelents to blending modes such as 'screen' & 'lighten', 'darken', 'overlay', 'softlight' etc. that you find in image editing apps?
Thanks, Shift Studio.
