Make Visible Solo/All.js
hello
this is macro script to make only selected object "visible in editor" on, and make all objects "visible in editor" on. place its into ~/Application Support/Cheetah3D/scripts/Macro folder.
I wrote this for my purpose, so these have some limitation. these 2 scripts will reset 'visible in render' info of all objects to On/Off. So, all settings about 'visible in render' of all objects that you changed before execution, will be lost.
http://www.tres-graficos.jp/blog/files/article.php?id=66
regards.
tg_jp, Hiroto.
How hard would it be to provide a similar function which would make everything but the current selection "wireframe" or "bounds"?
hi
yes, I attached customizable version of these macros. please check comment in script file.
regards.
edit: I added 'recursive' flag, for some parameters don't effect hierarchically as not like 'editorVisible'.
tg_jp, Hiroto.
  • Make Change_set.20110331b.zip
Hi Hiroto,
Would it be possible to make this only affect objects in a group?
Also, would it be possible to make all items in a group invisible except one, then toggle which one is visible?
Also, could the visibility be keyed automatically?
Matt
Hey,
What I mean is, I want to be able to keyframe the visibility of the objects.
you can add key for visible in render / visible in editor of mode tag.
please check attached file.
regards.
tg_jp, Hiroto.
  • modeTag_keyframing.jas.zip
hi,
OK. I misunderstood what you meant.
It's available to switch exclusively visibility of object(s) in a group while animation via script. but I think it's also available to separate a object(s) and others by folder, then add f-curve key for these visibility manually. It will be more simple than script approach. ;)
regards.
tg_jp, Hiroto.
