Importing SVG and converting points/lines to 3d objects
I'm new to cheetah but so far i'm impressed with the ease of use. I'm having a little trouble understanding how best to accomplish the following.
I have SVG file of a graph (sample attached) and I want to import it and then have the lines converted to tubes/cylinders and the nodes converted to disks.
Since the lines are imported as bezier splines, is there a way to take an instance of an object and then do a copy parameterized instance to splines? If so any pointers would be appreciated. (Basically hoping I don't have to manually extrude each spline/line and add the points.
Thanks,
IB
  • smallworld_100.svg.zip
Hi and welcome.
Are you expecting a scriptable solution as we are in the scripting area of the forum? If not - have a closer look into the attached file and let´s hope it might help you start with your project.
Your SVG is quite scary and I don´t know what you´re after right now.
I made a simple file from 2 splines and Cheetah3d´s instancing system. That means I have a ball per control point and a sweep object from the same spline plus a six-sided edge spline as a diameter.
Have fun.
  • InstancingPerSpline.jas.zip
Frank,
Thanks for the quick turn around. Your example helps, but I was hoping for a scriptable solution (programmer/designer by trade). The SVG is a social network graph and I need to be able to import several of these and turn them into 3D objects (although really they'll be 2d planes extruded and overlaid onto of some 3D environment scenery.
I would like the lines to act as springs for animation purposes (e.g. one of the visualizations involves introducing an impulse on a node and watching the waveform propagate through the network. I did find another post where you mention importing as pdf (this worked better for me and I was able to extrude) but when importing as a pdf it treats the entire network as one object which is problematic as i need to be able to color nodes and edges as part of the animation.
I'll take a deeper look at the example you sent and see if I can get where i need to go. If I haven't made things clearer in the above, please disregard and i'll wait till i can ask a better question.
Thanks,
IB
Hello
here is script's approach. please check it.
it's a Tool script, so place it into ~/Library/Application Support/Cheetah3D/scripts/Tool folder.
I tested with your file, and some my svg file.
regards.
tg_jp, Hiroto.
  • SVG Graph Loader.js.zip
This is awesome, I had to resort to manually doing this for a short term deadline, but this is exactly what I was looking for to start diving into the scripting capabilities of C3D.
Thanks again, its refreshing to find a true community around a tool and with such helpful guru's.
IB
Oh and for the search engines: This is a possible solution/pipeline for visualizing network graphs in 3D with gephi and cheetah3d
Hello
regards.
tg_jp, Hiroto.
Great script, thank you!
I'll take it for my own future script.
But it has some minor bug in S(s) svg tag handling.
here is mine:
Code:
[B]var cpx_last,cpy_last = 0;[/B]
case 'C':
[B]cpx_last = px2;
cpy_last = py2;[/B]
case 'c':
[B]cpx_last = px2;
cpy_last = py2;[/B]
case 'S':
var pos = dm[2].split(/[ \s,]+/);
//print( 'S4:' + pos.length + ':' + pos );
for (i = 0;i < pos.length;i=i+4) {
px[B]2[/B] = parseFloat( pos[i] );
py[B]2[/B] = parseFloat( pos[i+1] );
[B]px1 = px + (px - cpx_last);
py1 = py + (py - cpy_last);[/B]
px = parseFloat( pos[i+2] );
py = parseFloat( pos[i+3] );
[B]cpx_last = px2;
cpy_last = py2;[/B]
[B]splcore.curve(  ( new Vec3D( px1, 0, py1 ) ).multiply( scale ),
( new Vec3D( px2, 0, py2 ) ).multiply( scale ),
( new Vec3D( px , 0, py  ) ).multiply( scale ) );[/B]
case 's':
//print( 's4:' + pos.length + ':' + pos );
px[B]2[/B] = px + parseFloat( pos[i] );
py[B]2[/B] = py + parseFloat( pos[i+1] );
px += parseFloat( pos[i+2] );
py += parseFloat( pos[i+3] );
[B]cpx_last = px2;
cpy_last = py2;[/B]
you may see the difference in some control points.
Here the script.
Caution: before "Import" button clicking take the focus off from the scale parameter.
  • SVG Graph Loader.zip
