Baking
Baking
Hi all, I've never baked a texture before so forgive my ignorance. I've looked around the forum but can't seem to find the answer. I baked the texture of the ball and saved the mat, then applied the new mat to the ball, and this is what I get. The mat tag, bake tag, and ball all set to UV2. Any ideas? Are there supposed to be seams on the ball?
Terry
Hi Terry.
As the baking goes to the UV set2 enable "uv set: UV2" at your mesh and tangent space at your new material.
Hi Frank, would you mind looking at the file to see where I went wrong? All seems to be UV2. I must admit I've avoided the baking issue for a long time so I thought it might be nice to at least have a clue. :smile:
Terry
  • bake.jas.zip
HiTerry.
You have to change the applied texture against the baked texture. Make a new material and add the rendered /baked texture to the diffuse channel and add this new material instead of the first one.
HiTerry.
Okay thanks, Frank. Been playing around for a while and kind of getting the hang of it. I noticed in another thread baking doesn't work for reflective materials. But does it work on a model that say, has 3 meshes? I'm guessing the same principal would apply to baking, just 3 times, 1 for each mesh? Or would the UVs get confused?
Terry
What channels can be baked is listed in the "Bake Texture tag".
Whole scenes can´t be baked.
We had this topic quite a lot spread all over this forum - so a search on "Bake texture" "Bake scene" will give you some good reading.
Okay thanks, Frank, I'll read up.
Terry
