fbx import error
fbx import error
I received 2 files from turbosquid in fbx format that shutdown c3d when I try to import them.
I haven't had any trouble importing fbx files until these so I'm guessing they did something odd.
Can anyone tell me what I might try with these?
Thanks,
Mike Wheaton
  • export.FBX.zip
  • export(2).FBX.zip
I think there was something on this file that Cheetah does not support. Cheetah crash right away when i tried to open it.
This version should work.
Margus
  • export.fbx.zip
Hi Mike.
Can´t tell about the reason for the crash. The FBX came from "SDK/FBX Plugins version 2009.3"
I fixed and preserved the motion capture animation data.
Maybe Martin should have a look into it.
  • DogFBXfixed.fbx.zip
Crash while opening FBX
This fbx was created using C3D, it works perfectly in Unity but I cannot re-open it in Cheetah3d.
It is a simple place holder dummy geometry where I added few poses and few animations. I forgot to save the .jas file...:frown:
It is not a huge deal to make the dummy again, but would be interesting to know what might have caused this and if there is a way to recover?
edit: Console Message:
7/14/09 11:43:13 PM com.apple.launchd[114] (0x1095a0.Locum[283]) Exited: Terminated
7/14/09 11:45:10 PM [0x0-0x29029].de.wengenmayer.Cheetah3D[286] Cheetah3D(286,0xa0838720) malloc: *** error for object 0x1b11cdc4: Non-aligned pointer being freed
7/14/09 11:45:10 PM [0x0-0x29029].de.wengenmayer.Cheetah3D[286] *** set a breakpoint in malloc_error_break to debug
7/14/09 11:45:14 PM com.apple.launchd[114] ([0x0-0x29029].de.wengenmayer.Cheetah3D[286]) Exited abnormally: Bus error
  • Fighter_dummy.fbx.zip
Maybe Unity uses a different SDK than Cheetah3d.
Check the file please:
  • Fighter_dummyNew.fbx.zip
Thanks Frank,
Now it opens in C3D. But all the Poses are missing and Takes do not have any key/values. Does not matter, it was just place holder anyway.
Just curious, what is the normal process? If I have animations, I should use .jas?
edit: The animations are still there in Unity when I open the New version Frank sent.
Yes - store everything in the nativ Cheetah3d.jas file until you´re in the need to migrate somewhere - and do use export instead of "save as" - so you will generate a new independent file.
