could help me somebody to illuminate a Display?
hello together,
i have some problems, to illuminate a display.
i tried to put several lights inside my object and adjusted the area, wich should be illuminated, to transparent. and i added a texture to my material.
i dont get a satisfactorily result...
if i set the transparency to high, you can see the inner of the object, if i set it to low, there is no light passing trough...
wich kind of light i should use inside the object? could anybody send me screenshots how to adjust material and light?
thanks a lot, jan
Wow, it looks like your battery is dying in that screenshot. =)
I'm very tired at the moment, but you'll find some excellent help here. Hope this is useful. =)
you can also use the "Solid Color" material for the display. That material won't be effected by the light sources. So it should look always bright even in dark environments.
By,
