More cars
More cars
This car was modeled in TouchCAD and exported to Cheetah as DXF. I essentially wanted to see how it worked. The image comes from my third practice session so I'm still learning.
Re: More cars
Same model but from the back.
Re: More cars
And from the top.
Claus,
Very nice. Are you applying you textures and colors in Cheetah since you are importing a dxf-right? I have yet to get the hang of applying a lot of textures in Cheetah.
Jake said:
Claus,
TouchCAD has a special DXF mode for exporting to rendering programs where it exports color names used by TouchCAD as layers, so all objects come in with names that makes sense. I then generate the textures, in this case between 5 and 10 and drag it to the corresonding colors. In some cases you need to work on it a bit when you have textures with a direction and size. Cheetah does however not read the real DXF colors as it should so evertything comes in as gray.
/Claes
wow very nice renderings and very nice car model of course. :D
I will try to add the DXF color import to version 2.3 .
By,
