2 splines below addObject(SWEEP)
MarkusR
Member
hello,
how can I add two splines below a sweep object in script?
I need to create a frame with small and bigger rectangle.
i can not get the SplineCore context.
I try to create a window frame with parameter input, sweep with two rectangles and a box for the window glass.
I stuck at sweep because I not get the core() and I also missing a method to clear all path in the spline because new parameter will recreate it.
// default values var windowwidth = 1.2; var windowheight = 1.5; var frame = 0.05; var depth = 0.1; var sweep = null; var glassbox = null; /** UI */ function buildUI(obj) { obj.setParameter("name", "Window Frame"); obj.addParameterFloat("WindowWidth", windowwidth, 0.3, 4, true, true); obj.addParameterFloat("WindowHeight", windowheight, 0.3, 4, true, true); obj.addParameterFloat("Frame", frame, 0.05, 0.25, true, true); obj.addParameterFloat("Depth", depth, 0.05, 0.25, true, true); } /** create */ function buildObject(obj) { // create once if (obj.childCount() == 0) { var doc = obj.document(); sweep = doc.addObject(SWEEP); // darunter ein rectangle und ein kleines rechtangle glassbox = doc.addObject(BOX); // fuer die Glas Scheibe obj.addChildAtIndex(sweep, 0); obj.addChildAtIndex(glassbox, 1); } // read UI input windowwidth = obj.getParameter("WindowWidth"); windowheight = obj.getParameter("WindowHeight"); frame = obj.getParameter("Frame"); depth = obj.getParameter("Depth"); var left = -windowwidth / 2.0; var right = windowwidth / 2.0; var top = windowheight; var bottom = 0; // ------------------------------- the window frame sweep var core = sweep.core(); print(core.pathCount()); // SplineCore // small Rectangle Z // frame Rectangle Z var spline = core; // modCore spline.move(new Vec3D(left,top,0)); spline.line(new Vec3D(right,top,0)); spline.line(new Vec3D(right,bottom,0)); spline.line(new Vec3D(left,bottom,0)); spline.close(); // ------------------------------- the window box glassbox.setParameter("position", new Vec3D(0,windowheight / 2.0, 0)); glassbox.setParameter("sizeX", windowwidth-frame*2.0); glassbox.setParameter("sizeY", windowheight-frame*2.0); glassbox.setParameter("sizeZ", depth); glassbox.setParameter("name", "Glass"); glassbox.update(); // ------------------------------- }
seems I not saw the object type rect and spline ..
