Five Fold Islamic Design
I just recreated a five fold pattern guide and I must say, I did not think I was going to finish this one.
First of all, there are so many elements it hurts my head. Second the video I found had no instruction,
just 31 slides of each element without enough resolution to see fine detail.
I no longer use Circle Splines, instead I use N-gon Splines set
to have the correct number of points, in this case it's 20.
That way I have many snapping points where I need them.
Now we'll see if I made any mistakes when I try to make the actual pattern.
Here's the guide file in case anyone wants to play with it.
  • Five Fold Master jas.zip
Thanks for that one.
I'm having a hard time trying to apply the wrap modifier because the straight parts aren't tesselated by the sweep mod.
Also the missing denoiser is driving me nuts.
I have switched to Nurbs spline here.
This file has the guide splines and the pattern as well.
I also made a one piece version, all welded together with no overlapping.
@misoversaturated I tried the same sort of thing and found if I
creased all edges and then added a Subdivision Modifier,
I could then do bendy stuff.
  • Five Fold Master and Pattern.jas.zip
Thanks for the sharing the file Eric. I thought I'd try the modifiers to see what works on your model. I haven't really played much with these modifiers before.
The Spherify Modifier flattened the geometry.
The Bend and Twist modifiers worked well. The bend modifier would be useful for a barrel-vaulted roof/ceiling.
The Twist modifier has potential for a hyperbolic paraboloid roof (or perforated Pringles potato chip 🤣)
@misoversaturated How did you preserve the geometry when turning it into a dome?
