Hi guys,
If you want to work in A.D. in 300DPI (as an example) you can export to .SVG using the standard A.D. "SVG (digital - small size)" (in Affinity)
Calculation seems to be: WantedDPI / 72 (ScreenDPI) / 10 (so C3D do not scale up) = 0.416666666666667 so paste this answer into C3D > Settings > Files > SVG > Scale factor and C3D will round the number to: 0.416667.
Now you can work in 300 DPI in A.D. and get the exact same size ratio in C3D.
I tested with a a square 100 pix x 100 pix in A.D (think millimeters) and that means 10x10 cm in C3D.
I also tested 200 DPI = 2.777778 (C3D) and it works.
The reason for me posting is that some software only allows to export to 75 DPI etc which then means I constantly had to go and convert it to 72 dpi. And working with a low pix number in Affinity Designer would mean that I would have to have a document of only 150x150 pix to match my 3D printer = 15x15x15 cm print bed.
Now you can work in pix, cm, inches etc in A.D. and only do a final size adjustment there to pix before exporting. You could of course calculate the same for inches if you want to but I use mm / cm.
Hope this saves someone some time.
Moo.
Moo.
